Old 10-14-2011, 10:12 AM   #12 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Originally Posted by Rick Rae View Post
The Scangauge is capable of displaying pretty much anything available via OBD II (though manufacturer-specific stuff can take a little effort).
But there's the rub: it has to be available, and I doubt fan speed is. There'd have to be some sort of sensor on the fan. I've never seen that.
Cheers,
Rick
I believe my truck does have a fan speed sensor. I found some info over at the Cummins forum where somebody posted the diagnotic procedure to check and see if the clutch is working properly and it involves the technician hooking up a diagnistic tool and reading the fan speed and different engine rpms, so I take it it is and OBD II parameter.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
