Old 10-14-2011, 10:50 AM   #15 (permalink)
Rick Rae
Rick Rae's Avatar
The CARDIS - '07 Nissan Versa S HB
90 day: 30.9 mpg (US)
Originally Posted by Diesel_Dave View Post
I believe my truck does have a fan speed sensor... hooking up a diagnistic tool and reading the fan speed and different engine rpms, so I take it it is and OBD II parameter.
Awesome! Then you can probably read it. Scangauge's current firmware supports "X-Gauges" which are basically "roll your own." It might take some digging to find the right command(s) to send the ECU, but once you add them you should be good to go!
Cheers,
Rick
