Originally Posted by dcb
I had to do a quick experiment with a makeup mirror too, and a short extender cable  It is promising, it is brighter in real life and the lcd is currently limited to half brightness (and might be pulse overdriven to a brighter appearance). A LED array might not be a bad idea either, but complicated.
I was thinking if you mounted your gauge upside down 'then' reflected it to the windscreen it will/may display the right side up. ?
