Old 10-15-2011, 11:00 PM   #8 (permalink)
dfix9
Convert 2000 Geo to XFi
Thanks for the tip!
Originally Posted by mcmancuso View Post
just FYI, the computer in the XFi has a slightly different fuel map, the pistons in the XFi have only 2 rings and the top ring is gapless, but both those differences are really minor compared to the transmission ratio and cam (built in 6° advance).
As said above you can simulate the ratio change(if your car came with 12" wheels) by going to 155/80R13 wheels/tires, and an economy camshaft from 3tech or delta cam with a +6 gear from 3tech will simulate the XFi cam.
Thanks for the TIP! SORRY FOR DELAY. I'VE BEEN AWAY!
10-15-11
