Old 10-16-2011, 10:12 AM   #359 (permalink)
jackbauer
jackbauer's Avatar
Mounted the radiator on the enclosure today with a piece of aluminium angle and some 6mm threaded rod. Still not sure if I will mount the radiator in the passenger cabin. Depends on the amount of heat it pumps out!
ID:	9563   Click image for larger version
ID:	9564   Click image for larger version
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
