Insight MkI is not a car for everyone, either you like it, or you hate it! The Insight's design polarizes either HOP or FLOP
As a tall person you have to climb behind the steering wheel. After starting the 995 cc 3 cylinder 12-valve SOHC-VTEC engine, listening to its funny sound, you might think of a sort of a HOOVER vacuum cleaner
Are you familiar with pushing a clutch pedal and shifting gears, like a sportscar - OK - then for sure you'll might miss the power of a Mustang or even not yet?
You might learn a new technique of driving & moving a 4-wheeler from A to B in a most eco-efficient manner...
The green figures of 'MPG' on the cluster display behind the steering wheel will tell you instantaneously what happens, if you floor the accelerator or if you caress the accelerator.
To make a long story short: once in your life you should have the chance to sit & drive an Insight and the you may decide: YES or NO. If YES, then the Insight may take over and can teach you how to become a Hypermiler
