Old 10-17-2011, 09:09 AM   #14 (permalink)
meelis11
meelis11's Avatar
Green frog - '97 Audi A4 Avant 1.9TDI 81kW
Diesel
90 day: 43.1 mpg (US)
HAHA, very good results!
Probably you should try one gear down (4th instead of 5th?) so that engine is in right rpms from the beginning of the pulse. I just got my diesel so I am not expert at all, but Vekke writed that and he is getting really good hypermiling numbers.
Vekke, 10-10-2011, 05:16 PM
On diesel you have to make the Push with full throttle (97%). RPMs should start the push at torgue peak or rigth before it. On a 1.9 TDI that is about 1800rpm. Use the shortest gear that meets the RPM reguirement. Usually 4:th gear.
