Originally Posted by Sykomor
...Before I left work I made a quick lower grill block...
Coolant temp was mostly steady at 90C but occasionally went up to 95C. It's usually steady at 85C. Intake temp was about 18C while ambient was 9C. ...
Usually 87 for the WT (on the SG2) and ~23 for the intake.
This guy did a test of intake temps with the standard intake (I'm only reading your first post so excuse me if you have changed it in the second) and found a CAI to the standard filter makes no difference.
I've been going WAI - although its unproven, but the test above suggests no difference anyway.
...George needs a role model
He needs all the help and advice he can get from older folks
