Old 10-20-2011, 07:37 PM   #2 (permalink)
NeilBlanchard
Welcome to EM from a former Downeaster; now living in Massachusetts.
Have you done things like pump up your tires to the sidewall maximum? I can also highly recommend a ScanGauge or an UltraGauge for better and more feedback information. And upper grill blocks are hardly a wild modification, which will help both in aerodynamics and engine warm up time. Aero is doubly important in the winter, as cold air is denser and causes more drag.
Another possibility is a block warmer.
