Originally Posted by Patrick
A gallon of diesel has about 38 kWh. So the diesel unit burns 11 X 38 = 418 kWh in a day.
A Nissan Leaf battery pack is 24 kWh. So to accomplish the same amount of work as the diesel (ignoring differences in efficiencies), you'd need 418/24 = 17 Leaf battery packs. Probably not practical.
the 11 gal a day is for the gas model.
we just got are hands on a diesel model two weeks back and have yet to put it in service, it has some "real" safety issues with the canapy over the seat.
its missing a post, and cracks in many places, if a falling tree hit it. it would not pertect the person running it.
IE your dead..........
so in short, i don't know the hours per gal of a diesel yet...other then guessing.
im guessing it will use about 40% less fuel then the up-draft carb gas engine.
any way you cut it the original drive system is very thrifty considering when these things where made, over 50 years ago.....
If the diesel converts 40% of the energy into useful work and the electric system is 80% efficient, you can cut the battery pack number in half (40/80 = 1/2): 17/2 = 8.5 packs needed. The packs reportedly cost about $9,000 each (on the WAY low side). 8.5 X $9,000 = $76,500 for batteries. Of course if you go with lead-acid, the cost will be lower, but the weight will be higher.
lead-acid bats have 1KW right? or am i off base, 8.5 Nissan Leaf battery packs hmm thats a LOT OF LEAD BATs to = the 8.5 Leaf battery's with 24KW in each
even if that number was down around 6 packs that's still "way more" then i could fit on it.....
1 86 T\D trooper with rare GEN 3 rods
TRANS FIXED
NOW DD
1 86 4WD 5sp pup is 2.3L gas, but plan on 2.2L diesel repower
1 91 trop, long term plan is a group buy of imported Isuzu 4JB1-T 2.8L I-4 engines, hoping to get price down to 2K not 3K plus
1993 sidekick my MPG toy, epa rating 26.
i get 29/31 with stock drive train.
