Some more progress on the charger build. Got the control stage built up on a piece of 6mm clear polycarbonate. All of the i/o to the control board are terminated on a piece of barrier strip. Also mounted on the polycarbonate are the display screen and the push buttons. Mounted two epcos 4700uf 400v caps in the main enclosure and a piece of din rail for the input rcbo , earth point and output fuse. Also mounted a 12v 5A dc power supply for the logic and coolant pump.
Can't wait to fire this thing up
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
