Old 10-23-2011, 09:44 AM   #600 (permalink)
JasonG
JasonG's Avatar
05 DMax - '05 Chevrolet 2500HD
90 day: 18.48 mpg (US)
I haven't been following closely so sorry if I am out of line :
Using CTs on AC lines works great for motor amp readings........until they are placed downstream of a VFD.
The readings are based on peak amperage, sort of. A VFD sends full amps, but at a shorter duty cycle when running slower. We found the CTs would show near FLA when the motor was spinning at say 25%
Your control circuits and PWM may be different though.
In a VFD the only amp reading that is reliable is the one generated by the VFD itself. IDK is it is read from the DC bus or is an assumed value.
I can't understand why my MPG's are so low..........
21,000lb, 41' Toy Haulers are rough on FE!
