87 octane is fine as the timing will range from -5 to +50 degrees. Not sure on the fuel map but have seen fuel trim from -10 to +10 on the UG.
From what I hear you can safely run lots more compression with Ethanol.
This ain't a war, anymore than a war between men and maggots. Or, dragons and wolves. Or, men riding dragons, throwing wolves at maggots!
