cm400dy-12H by mitsubishi. rated at 400 amps each at 600 volts, i believe. i'm using four of them. just a tiny bit wider than the capacitor, and it will load the igbt driver evenly, two per channel. (using the dual channel VLA-500 and driver board that i got from mrbigh)
