Originally Posted by isaac_alaska
cm400dy-12H by mitsubishi. rated at 400 amps each at 600 volts, i believe. i'm using four of them. just a tiny bit wider than the capacitor, and it will load the igbt driver evenly, two per channel. (using the dual channel VLA-500 and driver board that i got from mrbigh)
Ah. I have a many of the CM400DU-12F from Powerx. They are actually made by Mitsubishi. I have a design already for the plates that holds 3 of the igbt's. I posted pics a little ways back.
As for the drivers. I have never done the math for 4 modules, but 1 driver can easily do 3 modules.
-Adam
