Originally Posted by Arragonis
Any updates on the regen issue ?
No.
Last time I asked - over 1 month ago - the dealership was waiting on word from Volvocars Belgium.
Sure looks like they've all gone mute there .
This hit UK TV last week with the BBC Watchdog program reporting issues with several Diesels - mainly FIAT 500s and Nissans but obviously not limited to those.
Issues with clogging or hyper-regenerating DPFs and EGR valves are fairly common. Bucking during regen is another issue.
Those who still think "clean" diesels are the solution, would better reconsider other options.
- A reprogram of the ECU to disable the DPF - not sure how this is done.
Can't be done, ultimately it'd clog the DPF.
Back-pressure would rise gradually, and so would FC.
Performance would drop off.
- An additive which cleans it out
How would they get it through the engine first ?
- A description on how to clear it out manually
That's pretty simple - at least in theory.
Disconnect the pressure differential tubing and (on mine) 1 connector and get the DPF out of the exhaust line.
Take a pressure washer and give it a good wash down.
Dry it out, and refit it.
Obviously, this releases the soot into the environment.
Equally obvious, it's a lot of work in a very confined engine bay.
In my case, it wouldn't help a bit : 2 new DPFs didn't solve the issue either.
Cleaning out the DPF is an alternative to having the DPF replaced - not to it's periodical regeneration.
