Originally Posted by 3-Wheeler
Hi Jim,
Hold tight and wait a while.
The tire rubber will get harder after 20 or so hot/cold cycles from running the car, then letting it sit and tires cool.
Whenever I put a new front tire on the motorcycle, I can really feel the grip of the new tire on the road during the first few rides. The handle bars are noticeably harder to push for turns as well.
After those hot/cold cycles are done, the tire feels much less sticky when turning.
The same thing will happens with our Insights after the tires harden somewhat.
Jim.
Yeah, I suspect as much myself. It is probably a breakin process which will take some little bit of time. The actual change in diameter between old and new is so negligible that won'g be likely to have any effect.
