Old 10-25-2011, 11:54 PM   #11 (permalink)
honfit
civic breakdown
Try tapping on idle air control valve located below throttle body while cranking engine. Also try to determine if spark is present at spark plugs by pulling one and grounding it against valve cover,also while cranking.
GOOD LUCK I work at a Honda dealership and this is the advice of 2 techs....
Honfit (Sean)
The Following User Says Thank You to honfit For This Useful Post:
California98Civic (10-26-2011)
