In wiki section there is code how to save tank parameters to eeprom - so you dont lose them if you want to disconnect mpguino sometimes or you get power loss.
I made some changes to my code so mpguino goes to sleep and consumes around 5-6 milliAmps. If someone is interested, I can check code and put that part here or in the wiki. It was quite easy actually, just added one line into that block where backlight is turned off.
