Old 10-26-2011, 04:06 AM   #13 (permalink)
jakobnev
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 80.56 mpg (US)
Send a message via MSN to jakobnev
I see you car has the same hair brained design with the ignition module and coil inside the distributor as mine. :P (Heat shortens the life of these things)
It seems as the pump is working(Do you smell gas at the tail pipe after an attempted start?)
(And you actually checked for spark right?)
With a brand new module your next suspects are: signal from the ECU to the module, and the ignition coil. (I guess B+ and ground to the module as well)
Lack of signal can be caused by bad cam angle sensors(or their wiring)
The Following User Says Thank You to jakobnev For This Useful Post:
California98Civic (10-26-2011)
