Looks great! Glad I could be some inspiration as it fits about perfect there when all is said and done.
Where did you end up mounting your switches?
Something to note if you do not want that wire showing through the engine bay... I tapped into the fuel injector lead at the PCM since it is already inside the cabin. Do not remember if I did the same with the VSS or not (slept a few times since then... lol)
