Old 10-27-2011, 01:05 PM   #3 (permalink)
sbfuller
Welcome to the site.
Sounds like you drive something with a big engine. You can probably accelerate from a stop in 2nd gear. What you are trying to do is use more throttle and less brakes. Look up brake specific fuel consumption (BSFC) for a good lesson on engine efficiency. If you can pass without downshifting that is the way to go.
Be sure to check out the 100+ hypermiling tips (link at the top of the page) too.
ok cool, will do. I just found the site so i figure i might as well get active here like other forums i'm on. I love the performance of a big engine, but also like to be economical when i'm not wanting to play
