Originally Posted by 96SATSL
I spend about an hour making the clear covers thru a vac forming method. I vac formed over the 16" pizza pans. I will show the process bellow.
Pretty clean? Will record any results ASAP. They run to the edge of the hubcap on the stock ones too and might ever try them on the OEM ones. This way my pizza pans also stayed in tact. Have both sets now.
Any thoughts?
-Alex
if you were to "seal" the hubcap interior that would reduce or eliminate the brake dust intrusion.
