Originally Posted by comptiger5000
The inner wheel-well guards may or may not make much difference, as they're not particularly exposed. Blocking the fog light holes would be worth it though.
That Jeep should already have an electric fan. If it has a mech fan, then it has both (tow package), and you're fine to pull the mech fan and run just the electric.
Also, be careful with grill blocking in warm weather, as the grille was made huge on these things for a reason.
Yes its got a tow package fitted, and has the electric fan. I've already deleted the wiring for the trailer, and have ben considering removing the tow hitch. So only the tow package models had the crank fan ? Thats good news ! I'll remove the tow hitch, crank fan and change the thermo-stat & coolant this weekend in that case
