Old 10-29-2011, 02:07 AM   #395 (permalink)
bdubnelson
Originally Posted by bondo View Post
Welcome to ecomodder pryan37bb.
Thanks for your input on the Aerolid. You are right on about the lack of rear visibilty. Lexan would be a good material to use. Safety glass is best.
One problem with increasing the size of the back window is torsional flex. In a perfect world one would always close the roof of the Aerolid by pulling down on it at the rear center only. But we not not live in a perfect world and the roof will be closed by pulling down on one side or the other causing the roof to twist. This would snap a cold peice of lexan.
Bondo
what if you used something like the window shade slats like the camero's in the 80s had on the back windows? It would give support and not block the view too bad.
Bdub
