Its alive!!! Alive I say! Had two small problems. Seems my secondhand 3 phase bridge rectifer had a shorted diode. Fortunatly , I powered up with a light bulb in series with the mains supply (old habits die hard!) so no damage was done. Moral of that story : don't use cheap second hand parts. Next the display told me my mains bus was at -900vdc. I missed out two pins on the arduino and pcb. Once they were fitted it ran up no problem with 300w of light bulb load. Now running a 240v 2500w electric oven element as per the photos. I'll have some video and more photos later if it doesn't explode
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
