Efficiency should be better than a normal right angle differential using gears.
Are you referring to normal driving or coasting?
I ask because the gears inside the differential don't move that much, and consequently can't be a source of significant losses. During coasting however, you'd have fewer parts moving with freewheeling clutches far out in the drive line.
