Paul , i guess i'm just lucky! most thing never work first time for me
Power factor won't be great on this version but i'm working on a boost pfc frontend that will bring it up near unity. I'm also considering running it on 3 phase where pf is not so much of a concern.
I took it up to about 3kw later on today then had a mishap! The battery sensing resistor got hot enough to burn through the insulation of the ground sense wire. Bang. And yes i got it on tape Took out the igbt , driver chip and dc dc converter. Vaporised the sense resistor. Got the bits swapped out and its now up and running again.
Here is some video from earlier tests :
I have to say I'm very impressed so far. No temp rise at all , very stable. I would like to identify the weird noise I observed on the scope in the video. Any ideas?
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
