Here's more ;If the mix is too lean, the converter won't have the right elements to clean the exhaust. Too rich and the converter will heat up to the point of melting, and trying to push exhaust through a solid block is tough. If your car burns oil or leaks coolant into the engine, these contaminants can collect on the ceramics inside the converter and cause it to clog. TOO RICH kills it. from
http://autorepair.about.com/od/gloss...catalyti_2.htm
