whats the equivilent of scangauge for house heat loss simulation?
Hi
whats the equivilent of scangauge for house heat loss?
what i want is a data logger like scangauge that measures heat energy used (gas) and all the temperatures in all the rooms and outside.
then i can play around with the thermostat and see if i can save.
or
a simulator software spreadsheet which calculates the heat loss in the house? so i can play with it and simulate different senarios.
i know the uk .gov site has a bit where you can enter the EPC certificate of the house and simulate adding extra insulation etc, but i want more functionality.
hope someone can help
Nissan Leaf 24kwh. Average FE = 300mpg 3.6miles/kwh (@plug)
