Ok, here it is, buy a hundred #10 nuts at the hardware and epoxy them equally spaced to the inside of a rear wheel rim. Make a bracket to hold the Hall cell in close proximity. You will generate a lot of fine resolution data. How to use the data I leave to the electronics experts ;-)
