Originally Posted by Waspswatter
I'm going to see how much I can improve the economy of my 2005 Ranger. No mods yet and I'm thinking about getting a scanguage so I can establish a good baseline. I've been reading threads all day and I'm anxious to get started!
Welcome to ecomodder !
The first step is to start recording your fuel use, if you aren't already doing so.
The major improvement is in how you drive, so read through the
100+ Hypermiling / ecodriving tips & tactics for better mpg - EcoModder.com
and start applying those you see fit.
The main tips are to
- drive slower, your average might be just as high despite the lower cruise speed ;
- keep it rolling as much as possible;
- not waste energy accelerating to a stop further down the road;
- reduce your idling time.
Avoid manoeuvring with a cold engine, park so that you can drive straightaway .
As for mods, check out the
65+ Vehicle modifications for better fuel economy - EcoModder.com
You may object to some of them, but the most common ones are increased tyre pressure, a blocked front grille, an air dam, and getting rid of stuff you don't need to haul around all the time.
