Old 11-01-2011, 10:57 AM   #35 (permalink)
Arragonis
The PRC.
I suppose AC for you is like heat for us. We replaced our condensor boiler (hot water heating system / hot tap water) just before last winter, and that cut the bill by about 15%. Added cavity insulation (houses here are brick with air-blocks in between) last spring so hopefully that should help some more. Just need to do my loft space floor but that means emptying everything out, no time so far
EDIT -
Originally Posted by PaleMelanesian View Post
I'm at 22% for all vehicle expenses and electric.
Do you mean 22% each or combined ? I got the stat wrong, apparently it is if you use more than 10% of your income to maintain a reasonable heat regime in your house. Not sure if income is gross or net of tax, or what a reasonable heat regime is specifically.
