Old 11-02-2011, 12:04 AM   #3 (permalink)
user removed
There are tests you can perform to see if the rings are your problem. PCV system, if plugged up could contribute to the problem, considerably in some cases.
Cylinder compression test.
Leak down test, then add some oil to see if the leakage is ring related.
regards
Mech
