I think it's pretty much a wash. While the kinetic energy that spins up the engine (when you don't rev-match) was likely generated at higher mean engine efficiency than you get while rev-matching, that energy had to go back and forth over the drive line, causing significant losses.
So go ahead and rev-match if it makes the journey smoother.
