Old 11-03-2011, 01:19 PM   #4 (permalink)
office888
Originally Posted by California98Civic View Post
Do you know if it will deliver the power in the low end? That's the key, from what I have read. For the best FE results you will want more power on the lower end of the RPM band and you will want as little delay as possible. This unit offers that?
The TD04-13G is fairly small. I can't say for certain due to variables, but full spool at 5 psi would probably be around 2700 rpm. I spend most of my driving in the 1800 to 3500 range. The extra power would be nice for getting onto the highway.
The GT15 would probably be a little more efficient for my needs, and spool a little faster... However, that would increase the price by quite a bit.
Originally Posted by Ryland View Post
Doesn't the CRX HF have pretty high compression ratio already and with a turbo you want to have lower compression on your engine so the increased pressure doesn't cause pre-detonation.
9.1:1, so not terribly high. There's a lot of guys running 15 psi+ with much bigger turbochargers with that compression.
