About 1 hr of finish sanding and then these panels and the rest of the car will be buried in a few coats of poly-primer (4 coats on areas with bodywork, 2 coats on the rest). Poly-primer is an extremely high build primer (actually a spray filler) that allows you to block the car out lazer straight without several priming sessions. This will be sanded with 80 grit, then 180 grit. I then will spray the normal 2K urethane primer that will be blocked with 320, then 600 grit. Then... it's spray time! Still deciding on what color to shoot, would like to use up some excess product in the shop... but I may just go with the stock milano red.
