Originally Posted by sawickm
Hi Adam,
Your "Uprising" Controller PCB Layout looks great !!! can't wait to see how it performs !!!
Question, if I wanted to add a TPS, or HEPA throttle to your controller what modifications would I need to make?
Could the next revision of your controller, have a throttle circuit with the option to install either a POT, TPS, and HEPA throttle ???
I know the Soliton and Zilla have that option.
Anxious on seeing your Driver PCB too.
-Mark
Alright,
I have updated the Schematic and Board to include dual throttle inputs. This will allow use of HEPA throttles and dual Pot throttle options.
Throttle options should be:
Single 2 Wire Potentiometer
Dual 2 Wire Potentiometer (Inverted or Normal)
Single 3 Wire Potentiometer
Dual 3 Wire Potentiometer (Inverted or Normal)
Single Hall Effect Sensor
Dual Hall Effect Sensor (Inverted or Normal)
If you asked me when I picked the 23 pin connector, If I thought I would ever come even close to filling it, I would have said hell no. LOL well im only 2 pins away from filling it.
I originally had the 4 closest pins to the ones carrying the main pack voltage with nothing in them so nothing could flash over. Well I ended up using the 2 on the next row down. They are now logic grounds. After reading the data sheet for the connector some more, I found the connector can withstand 1000VAC without flashover. I will test and make sure 400VDC doesn't.
The pictures should update themselves.
-Adam
