Old 11-05-2011, 12:40 AM   #9 (permalink)
RobbMeeX
Bertha - '16 Mercedes Benz Metris
Does it have a cable detent? if so you can loosen it for a little adjustment. Also if you can tie into the ecu, you can switch the OD solenoid to ground and have OD on command.
