I'm leaning towards the sand rail, space isn't an issue, all I need is a two seater with enough cargo area space for a couple duffel bags for weekend drill (proud weekend warrior, upcoming vaction to Afghanistan will fund this project). Check out the 2nd post in the link below.
First EV - Sandrail, low range low speed, for now... - DIY Electric Car Forums
Something similar to this but with a full body would be perfect, I could go for a rear engine and use reverse cut gears in the axles, shifter would be trickier though.
