Calibrating the odometer is reasonably easy to do on a road/highway with distance markers at say 0.1km or 0.1m. If you drive 20-30 miles you will probably see that the odometer either under reports or over reports the distance vs the actual distance. If you have a good GPS unit, that can also work.
