first you need to find out what the code is if there is a autozone near you or orieleys they will scan it for free dont just buy the part tho becuase most can be tested to verify they are bad i would suspect they may have left something unpluged or allowed it to ground like melted the o2 snsr wires to the exhaust good luck oh and you may check with the local tech schools or hs to see if they work on cars for people good luck
