Old 11-06-2011, 01:05 PM   #25 (permalink)
godscountry
it depends
constant blue smoke at any speed is most likely rings,smoke when stopping at a light[motor is at max vacuum] and part throttle is valve guides and or valve stem seals.You get a big puff of smoke off idle and then it clears up as you come up to cruise speed.Have someone to a leak down test of the cylinders to see where the problem is,don't guess,it can be costly.
