when you block off your air flow you will lose FE due to AIR to AIR effenciency loss ... air flow is critical to fuel economy with an air to air aftercooler ... if you want to reduce air flow you would have to move your air cooler to a different location and then install elect fans ... i dont think its worth the trouble
