Old 11-06-2011, 07:04 PM   #59 (permalink)
chvycmmnslvr
Its been my experience that when you cover your bed or drop your tailgate you lose FE .... the reason behind this is that you develope a high pressure pocket in the bed of your truck ... the tailogate catches air ... yes ... but you get the same amount of pressure against the rear of your cab ... resulting in push ... with a a greater surface area .... this actualy means that your best effenciency is with tailgate up bed empty...
