Old 11-07-2011, 07:51 PM   #3 (permalink)
Patrick
Patrick's Avatar
Hot Tamale - '10 Toyota Prius III
Have you changed/cleaned the air filter?
You also might try a catalytic converter cleaner.
I used to run the fuel tank down to a couple gallons of gas then add 91% isopropyl alcohol (2 pints, available at your local drug store for a couple bucks) to the tank and drive around for about a 1/2 hour before I went in for my smog checks. At that point the car was making oxygen. This may not be legal where you live, so check the law first.
The Following User Says Thank You to Patrick For This Useful Post:
wollbs (11-08-2011)
