Old 11-08-2011, 04:20 PM   #10 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
I'm not really familiar with the Ultragauge, but I believe %Load is an estimate of the amount of torque your engine is producing, divided by the max torque at that rpm. Torque is basicaly propostional to fueling. On a gas engine fueling is proportial to air flow and air flow is proportional to intake presssure. On a diesel, the ECM commands the fueling directly.
As far as the usefulness goes, %Load will basically tell you where you are vertically on a BSFC map (0% is at the bottom, 50% is halfway up, etc).
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
