Old 11-09-2011, 08:31 AM   #4 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
I've read about people using bio-diesel in 2 stroke gas engines instead of regular two stroke oil to mix with the gas and having good luck with a 10 to 1 ratio and as thin as a 20 to 1 ratio, around here it's not uncommon to find a 50 to 1 ratio of diesel to bio-diesel (B2) at the pump at filling stations.
Yes Wisconsin and Minnesota salt their roads in the winter, if you have bare metal that you don't want to rust and plan to spend a bit of time in the area then paint it or better yet, paint it then apply self healing rubberized undercoating, you can get it in the gallon can or in the spray can.
The Following User Says Thank You to Ryland For This Useful Post:
larrybuck (11-10-2011)
