This won't work on turbo engine or SC either, as OEM spring loaded PCV closes off when IM enters boost condition . Then your using the vent connection from valve cover to intake to remove any combustion gases during boost .
They would need to sue another controller with MAP sensor to close off at boost or maybe add check valve but that defects the propose as that is all most PCV are ..
