The RV toilet just makes so much sense.
It made me sick to use 2 gal of fresh water to flush 1 cup of pee.
Wife didn't go for the Mountain/Fl Keeys saying "If its brown, flush it down, if its yellow, let it mellow"
The only must is that it goes to a tank then is sent down the drain in batches.
If you don't, the solids and paper will settle in the pipe as there is not enough water to clear the pipes.
Easy install if you have a crawlspace. Weekend project, no need to have the house tore up for weeks. Shouldn't take more than 4 hours with a helper.
